주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone 5s home button, charging port, mic not working
Hi, i have found similar topics though from this forum and other forums, but didnt find any excatly the same. Hope you will find some minutes to answer my question. I replaced my battery and after replacing home button and charging port and mic not working. I didnt check my headphones jack and cant do it since my battery is dead and i cant recharge it. Weird thing is if i connect my charger to a completely powered off phone then it shows up that empty battery image, so it does recognize my charger somehow. In my opinion i replaced battery clearly, not damaging anything else. But i dont know what to do now. I dont have the parts yet but trying to replace charging port with mic. Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I just answered a similar (yet different) question over Loudspeaker doesn't work after replacing battery.
Did you follow this guide exactly?
If you pried the battery (instead of the pull tabs), double check the dock and battery connector and the surrounding passive components (they are tiny, use magnification). You may have dislodged some components or damaged the connector. Should this be the case, it will require a micro-soldering repair and is not DIY.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks for the answer. I may have damaged the cables, but im gonna check.
댓글 달기
귀하의 답변을 추가하세요
Mart Martt 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 562
