주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Loudspeaker doesn't work after replacing battery
Hi there, I can't find any fix to my problem anywhere, so I decided to ask here:
I've purchased a new battery from this site, replaced the old one and everything works... except for the loudspeaker. I bought another loudspeaker (original) and replaced the old one, but no luck.
Could you help me?
Thank you =)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Did you follow this guide exactly?
There is really no reason for there to be any impact on the speaker. So here are some things to check:
  • If you pried the battery (instead of the pull tabs), double check the dock connector and the surrounding passive components (they are tiny, use magnification). You may have dislodged some components or damaged the connector. Should this be the case, it will require a micro-soldering repair and is not DIY.
  • Also check the contact points under the speaker and on the Dock flex. Clean them with IPA (alcohol).
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Could it be a damaged connector even though everything else does work?
I did follow this guide, yes.
댓글 달기
@monsieurdaz, Anthony, Check all phone audio settings and be sure volume is up and not muted. You can try a reset,hold the power and home button for 20 seconds, or until the screen goes black and the Apple logo reappears. No go look in ear phone jack for dust/debri and pick/blow it out, plug in head phone(in and out) a bunch of times to see if internal contact sticking. Recheck the connection for speaker/head phone jack and make sure wires/cable damage and pins are not bent. 1st link is to a detailed article on your iPhones issue with trouble shooting tips and advice.
https://www.payetteforward.com/iphone-sp...
iPhone 5s Lightning Connector and Headphone Jack
iPhone 5s Lightning Connector and Headphone Jack 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Volume is up, headphones work, no dust, Bluetooth disabled, the hard reset didn't solve anyhing... =/
The lightning/headphone jack connector DOES however look bad, so that could be the problem... but everything else works, so I'm not 100% sure.
@monsieurdaz, Anthony, if looks bad, you should change it, link below should help. Good luck with your 5S.
iPhone 5s Lightning Connector Replacement
댓글 달기
귀하의 답변을 추가하세요
Anthony Michalyk 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 989
