주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PS3 display is not working
I'VE ALREADY TRIED THE HOLD DOWN that "resets" the display but doesn't work
I've tried different hdmis, and different ports the controler isn't turning on all the way and there's no yellow light. Along with it is no audio. All the answers I see are the hold down the power and reset but that is not working for me. My TV is fine it displays no signal and I've tried it onto different monitors it was working fine yesterday.
Any help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
Have you tried AV cable instead of HDMI? Tell me about lights, do you turn console on and green light is there as it should be, but no signal on tv? If so you may have GLOD. Or, maybe try to jiggle hdmi port a little see if that helps, if you get video that way, your hdmi port may be loose.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Can you help identify the issue with my PS 3 console, when turned on it only displays black and white dots
댓글 달기
답변을 추가하세요
Maxie Masters 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 15
전체 시간: 448
