주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1103 / 1.25, 1.33, 1.42, 또는 1.5 GHz G4 프로세서
Flooded Mac Mini Power Adapter
The area where I keep my mac mini was flooded with the mac mini turned off. The power supply was actually full of water as it was laying on the floor. After drilling a hole in the power adapter to drain out the water, and allowing it to dry out fully, it still will not power on the machine at all. What are the chances that only the power adapter is bad and not the mini also? There is no way to test it since I do not know anyone else with this same power adapter. Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Did your mini get wet at all? If not you should be OK.
The hard part is finding one of these older power bricks
의 공유
Thank you for your opinion. I have found a power brick on eBay for less than $20.00. It is worth the risk to see if it will work.
의 공유
댓글 달기
답변 1개
선택된 해법
afraid some items might been blown or shorted,
even that, water contribute oxidisation and corrosion to the electronic parts, circuits and traces.
maybe consider to get from ebay or... lend one 3rd party universal adapter, e.g. acbel, etc which can set around this range, Input:: AC100-240V (worldwide use)
Output:: DC18.5V 4.6A
Power:: 85W.
to test before purchasing it.
http://www.erepairstore.com/85w-a1105-ac...
Update (06/30/2017)
이미지
i think the connection is slow... but a screenshot
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
@salmonjapan could you check that link, I can't get it to load
의 공유
댓글 달기
답변을 추가하세요
ndwig 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 440
