주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
C720은 Acer에서 출시한 저가형 ChromeOS 기반의 Chromebook입니다. 2014년에 C710의 후속 모델로 출시되었습니다.
Why does my chromebook keeps crashing?
i recently bought it and i noticed that it oftem randomly shuts down. though i can turn it back on, i find this occurance to be happening a lot that i find it annoying... around how much would it cost me to have it fixed?
thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
It depends on what is crashing your computer. Do you get any error messages or the Blue Screen of Death showing briefly? Does the computer slow down and finally shuts down? These kind of errors are generally indicate a problem with the operating system. If the computer shuts down very quickly, this may be a heat problem with your computer. Most hardware problems are consistent and shut down or not start up at all.
The cost to reinstall the operating system should not be too much and you can probably do it your self. Repairing hardware depends on the part that failed, the system board is a higher cost to repair than memory. A good tech should be able to sort out if the problem is hardware or software and give an estimate of repair cost.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Christine Aquino 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 2,224
