주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 7월 28일에 출시된 New Nintendo 2DS XL은 기존 2DS 휴대용 게임기를 기술적으로 개선한 리모델링 버전입니다. Nintendo DS 라인업의 아홉 번째이자 마지막 리디자인 모델입니다. 이 게임기는 원본 2DS 모델보다 훨씬 크며, 업데이트된 'New 3DS' 시스템 라인업의 모든 기능을 추가했지만, 상단 화면에서 입체 3D로 게임을 즐기는 기능은 제외되었습니다.
How do I replace the Bottom screen and Top Screen
Hi, someone through my bag, and it dropped onto a tree stump. Both of the screens are damaged on my 2ds xl, the top one has lines going through it and the bottom touch screen is fully smashed, and won't work at all. Everything else works fine, the controls, speakers and all that but I just want to know weather it would be better to buy a new one, or to repair the one I have already.
Thanks and Cheers of all of you who have an answer to this problem
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 4개
I have a problem like this,the bottom screen of my 2ds Xl is not functioning due to a dent and scratches. I'm only a kid so no money,how do I fix the bottom screen?
You’re gonna have to buy a replacement screen. Luckily, not too much. Probably $15-$30.
My bottom screen works fine but the top screen feel off do you no how to fix it?
So exactly the same thin as Liam but the top screen also I lost one of the connectors so I can not reattach the top screen do you know if I can get a replacement?
댓글 달기
답변 3개
선택된 해법
Hi!
While you can replace the bottom screen, the top one is, as @johnwp mentioned glued to the entire front panel.
You could follow this guide if you wish to fix your console yourself, you will only need a good source for the bottom LCD & digitizer and for the upper front panel. You could try AliExpress or eBay I guess.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Where would you find a replacement for the top screen? eBay has none for sale.
Thanks
JB
댓글 달기
The top LCD is NOT glued to the entire top glass. There is adhesive around the paremeter of the LCD holding it to the glass. If you haven't actually taken it apart, please do not give people the wrong information.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I don't think the top screen can be easily replaced. The top screen is a whole unit. There is liquid between the plastic and LCD. If you take the LCD away from the plastic piece it will only further damage it. As far as I know the only course of action is to send it in to Nintendo. Can anyone verify this?
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
Oh, my brother smashed my top screen while I was sleeping, I have CFW, can I send
it to Nintendo even though it is hacked, and how much will it cost?
If you can blindly navigate GodMode9, than you can uninstall CFW easily. It will cost $50 to send it to Nintendo, not including shipping.
Weird seeing SirNapkin here, also, I bought a new screen for $60
There is no liquid in between the plastic and the LCD, you cannot easily remove the LCD from the chasis without damaging it. But you only want to remove it when its damaged anyway. Can it be replaced, !&&* yeah it can
댓글 달기
답변을 추가하세요
Recco waite 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 35
전체 시간: 7,476
