주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
"세계에서 가장 작은 15.6형 노트북인 이 제품은 강력한 성능과 놀라운 InfinityEdge 디스플레이를 갖춘 Dell의 가장 강력한 XPS 노트북입니다."
How do I replace the audio jack?
My audio jack is faulty. Can't afford a new motherboard. Where can I find a replacement audio port?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
Actually, the XPS15 9550 is barely or under a year old. Dell should replace it for free. IF not, check the credit card you purchased with, and they may cover the warranty for an extra year.
의 공유
It has a broken headphone jack stuck in it. Dell said it won't be covered under the warranty period as its negligence/damage.
의 공유
댓글 달기
답변 1개
The audio connector is part of the mother board. Unfortunately, Dell has decided that this problem is not warrantable. You may be in luck if the problem is a broken off part of a head phone jack and not a broken connection on the mother board. You may be able to remove the boken head phone part by using tweezers or use a paper clip bent into a small hook to pull the broken part out. You may be able to find a computer repair shop that can do this for you. Worst case is you may need to use a USB type audio head phone. Good luck
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ketan Krishna 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 19
전체 시간: 1,670
