주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 GHz (Turbo Boost 최대 3.7 GHz) 쿼드-코어 Intel Core i7 프로세서(6MB 공유 L3 캐시 포함).
Constant buzzing sound from right speaker
Hello,
A few weeks ago my MacBook fell from the front passenger seat when I slammed on the breaks and then it started making a crackling noise every once in a while.
It sounded like this https://www.youtube.com/watch?v=rx7Nwp9S...
And now its gone worse, it has a constant buzzing noise through the speaker and even when I plug in my earphones in the headphone jack. And the noise increases and decreases by changing the volume.
However when I plug in a thunderbolt dock, the noise goes away.
https://youtu.be/B-hlTRGn4nc
Now, is this something that is user serviceable? If so, which parts and tools do I need and can I get them from iFixit?
Thanks for any suggestions.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
bump................
댓글 달기
답변 3개
선택된 해법
Here you have a the removal process for the speakers and here the parts to buy to replace it. Is hard to say that your problem is other than the speakers. It does not cost you much to try and see if this will do the work>
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks for the reply.
Just as I was going to place the order, I checked the speakers again because I had put the sound balance all the way to the left, and surprisingly its not buzzing anymore. This doesn't make any sense.
Everything is back to normal and its not even making that crackling sound anymore.
댓글 달기
Found this thread on Google; figured I’d leave my comment here in case someone else finds it useful.
My right speaker started crackling shortly after I replaced the battery in my 2014 MBPr. It turned out that I had accidentally pinched one of the speaker wires upon reassembly. Applied some tape and tucked the wires under the screw mount and all is well again.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
For replacing the left speaker, is it really necessary to strip it down completely? I dont want to remove the battery or anything, its all good.
Is it not possible to get the speaker out without taking out the main board first?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
ok, I disassembled the whole Mac and then replaced the old speaker with a spare one, it now works again.
댓글 달기
답변을 추가하세요
A AM 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 19
전체 시간: 33,637
