주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Dimension 4700 데스크톱 컴퓨터는 2004년에 출시되었으며, Intel Pentium 4 프로세서, DDR2 RAM, 운영 체제로는 Windows XP를 탑재했습니다.
Can I fix a boot up error?
Receive the following message upon boot up attempt: windows root file missing, need to install windows root file<windows root>\system32.\hal.dll
My question is: can I do this and where do I find the file? Thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
Depends on your version of Windows. If you can press F8 a bunch at boot and get into Safe Mode, then you're not totally rooked.
The file can probably be found on your Windows cd and might be named hal.dl_ (just renamed it)
If you boot off your Windows CD and try to install to C: again, it should also prompt you to do a repair instead. (Not repair console - repair reinstall)
If you don't have a Windows CD and just have a manufacturer restore disk, this usually wipes the hard drive.
Either way, do a Scan Disk once you get your computer working again.
The good news is, your data's probably still there, and a tech savvy friend/family or a computer shop should be able to pull it off onto DVDs or an external hard drive.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Here is a link to some things that you might be able to try to fix it.
http://pcsupport.about.com/od/findbyerro...
Let us know if one of these works!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
One of the first action to take in case you have difficulties with the MSVCR100.DLL file will be to examine whether you are utilizing a 32-bit or 64-bit Windows version.
Useful article about this http://www.msvcr100dll.com/
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Depends on your version of Windows. If you can press F8 to bunch at boot and get into Safe Mode, then you're not totally rooked.
Cd and might be named hal.dl_ (just renamed it)
If you boot your Windows CD and try to install C: again, you should also prompt (Not repair console - repair reinstall)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
gdbtrbst2u 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 25
전체 시간: 2,186
