주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1001 또는 A1025 / 667, 800, 867, 또는 1.0 GHz G4 프로세서
PowerBook G4 Titanium 800 MHz Lock-up
My PB G4 Ti 800 MHz will start OK, but after ten minutes of being using any application, it locks-up and I have to do a reset to get control o f the computer. Also I can only the lower slot for memory. If I install memory in the upper slot only, I get the tone as if no memory is in stalled.
If I do not run any application the will not lock at all, but as soon as start an supplication the PB locks-u again :-(
Update
My HD is not dying it works just fine. The problem I believe is with something on the motherboard. The computer will boot but I can only use it for about 10 minutes. Then it locks-up. If I shut it down by pushing the power button until it powers off and restart the computer it comes on again for another 10 minutes.
As for cleaning the upper memory slot, I have already this as well as clean the edge of the memory module.
Thought there was a recall a very long time ago PB G4 Ti computers that had problem with their memory slots.
Does anyone remember this type of problem?
Walter
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Here is a link to Apples test procedures. In particular I would like you to run disk repair. For the memory problem only being able to use one stick is a common problem but you can try cleaning to socket with alcohol. Make sure the unit is unplugged and the battery removed first.
I hope these measures help you.
http://support.apple.com/kb/ts1417
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Sounds like your hdd is dying.. Time for a new one
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
walter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 1,553
