주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Oppo Electronics Corp.에서 제조한 휴대폰에 대한 수리 안내서 및 지원 정보입니다.
Touch screen not respond
The touch screen works only in the recovery mode
I have done hard reset and still the problem !!?????
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 17
댓글 6개
My phone touch screen is working but display is not working what the problem with my phone
의 공유
मेरे फोन का टच नहीं काम कर रहा है
의 공유
My screen isn’t working at all but all bottons on the side are all workin
의 공유
Oppo r831k touch not working
의 공유
I'm using Oppo Reno 2z screen not responding
의 공유
댓글 1개 더보기
댓글 달기
답변 6개
선택된 해법
If I'm not mistaken you navigate with the volume buttons and the power button in recovery mode so you don't use the touch screen . So the digitizer is not working so as you did not specify which oppo phone you have I canot direct you to a digitizer but you can find them on ebay or amazon . Oppo Phone
This guide page will show screen replacement for 3 different oppo phones . Hope this helps
이 답변이 도움이 되었나요?
점수 4
댓글 9개:
I have oppo a37
My problem is there is no responding from touch screen at all ,so I tried to fix the problem with hard reset but it not help
When I was trying to do the hard reset i see touch screen Respond well but only in the recovery mode ,after reboot the phone to normal mode still the problem no responding from touch screen .
의 공유
hi I am currently using f1s screen can’t be touch no response what will I do?
의 공유
jimfixerir i just replace the lcd with frame the led lights lighten up the back buttons lighten but the screen doesnt work, it is still black but it rings there is a soundwhat might be the problem? for oppo f1s
의 공유
ओप्पो a3s का टच नहीं काम कर रहा है
의 공유
I am using oppo reno 6z 5g. The touchscreen was unresponsive. I tried hard reset but another problem arises. It opted me to enter my password. I cannot enter my password for the screen is still unresponsive. What will I do?
의 공유
댓글 4개 더보기
댓글 달기
Same issue here i cannot touch in recovery mode .
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
i have same problem, new screen, working on boot to enter pin, but not working in recovery so i can't reset it. oddly to reset oppo recovery ask me a 4 digit pin that is displayed but i can't enter it because i can't touch numbers...
is it a display hw problem or a sw limitation of the oppo phone? mine is a54s
의 공유
댓글 달기
Mine is on recovery mode and i can't touch
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My phone is broken and screen is out 3,4 inside a paper
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Haval 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 24
지난 30일: 125
전체 시간: 52,748
