주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2266 질문 전체 보기
How do you fix the screen crease after replacing the screen?
iPhone 7 was broken and purchased a new LCD screen replacement part online. Before install the screen, I tested the screen and it works normal, but after assembling the screen and turn on the phone, there is a bruise on the screen . Why does this happen and should I pay more attention to some place when install the screen?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi Kaye. Do you mean something like what is shown in this question What is causing screen issue after iPhone 5s battery replacement?
If so, then those are pressure marks. That means something isn't sitting right underneath the screen and it applies pressure against the LCD when you press.
Go back through the screen replacement guide and check to make sure everything is in place.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
I should add a mark that doesn't go away will likely need a new screen.
@danj good point. If the OP gets back to us with more detail (or pictures), we'll be able to tell if the damage is temporary or not.
댓글 달기
귀하의 답변을 추가하세요
Kaye 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 12
전체 시간: 312
