주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Verizon에서 유통하는 Ellipsis 7은 7인치 디스플레이와 1.2GHz 쿼드코어 프로세서를 탑재한 안드로이드 4.4 KitKat 태블릿입니다. 모델 번호 QMV78로 식별할 수 있습니다.
battery charging and lasting
i have a Verizon Ellipsis 7 for a few years and the battery has suddenly start to do worse and worse I plug it in then 13 hours after it gets to 100% and i go start going though my instagram feed and 5 minutes later the battery is on like 39% and i wonder if I reset it ill fix it or what if anyone has a suggestion on how to fix it please let me know
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
A few things to try:
1.) Let the battery completely drain and recharge to 100%. By completely drain, I mean let it run until it shuts itself off. Then wait 15 minutes, turn it back on, and let it run until it shuts itself off again. This will ensure the battery is discharged. Then charge it to 100%. Hopefully, this will recalibrate the battery and let any "smart charging" software figure out the 0% and 100% levels of the battery. https://www.androidpit.com/how-to-calibr...
2.) If the above doesn't work, you can reset the software. https://www.verizonwireless.com/support/...
3.) Replace the battery. Verizon Ellipsis 7 배터리 교체
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Wait, that guide does not show how to replace the battery, only the charging port.
Even if replacing the battery after removing the back cover is a no-brainer: just disconnect it from the motherboard.
의
It does appear that the guide is mislabeled as a battery replacement. However, it is still useful... Look at the last step. You can clearly see the connector for the battery, where the black-film of the battery has the "+" and "-" on it.
의
댓글 달기
nice like it thanks you
if you are a developer android buy installs for your app to promote your app in the ratings and analyze the market
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I couldn’t figure out how to take off the back panel.
의
댓글 달기
1. Turn it off
2. take the back off the tablet
3. unhook the battery and let it sit for about a min.
4. re-hook the battery
5. Turn on and see if that fixed it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
SQUEAKER_GAMER 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 3,070
