주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
전자 키보드 수리 및 분해 안내서입니다.
Casio Sk-60 replacing missing on/off button
이미지
Hello, i am new here!
I need help with this vintage Casio Sk-60 keyboard, it needs a replacement for that missing (slider) switch. I would love to repair it!
I know how to solder simple things. Adding a lineout or connecting two cables ;) but i am totally lost on this one.
이미지
Here you can see on off i prepared for the keyboard. When it will work i will drill a bigger hole for it.
이미지
Thats the inside of the keyboard.
이미지
And here you can see the part where the switch was. The upper position was (On)
I also found this sceme here, but i dont get it...
이미지
I was hoping that maybe someone here sees the solution right away and can help me out. That would be great!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
@prokrastinator what you posted is not a schematic but a board layout view. It will not tell you how to connect a switch. You need the wiring diagram for that. I got this from the manual
이미지
Now you need to figure out on the board view which point is what. Going back to your image and checking the layout and schematic it appears that connecting a switch the way as pointed out in my pictures should work.
이미지
이미지
이미지
always double check with a meter to make sure that you do not close any power to ground circuit.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thank you <3
That helps a lot!
댓글 달기
Hi,
I got same problem but i don’t understand, is it solder a spst switch between vcc and vdd with 777 on center ?
Help much appreciate
thanks
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
- is it solder a spst switch between vcc and vdd with 777 on center ?
- no. it is solder a double switch, one part between vdd and 777 with what ever it is on center (those longer graphite bars are center). another part is between vcc and nothing with the other longer bar on center.
댓글 달기
답변을 추가하세요
Prokrastinator 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 1,568
