주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z5 안드로이드 스마트폰은 2015년 10월에 출시되었습니다. Sony Xperia Z5는 5.2인치 1080 x 1920 픽셀 디스플레이를 특징으로 하며, 퀄컴 스냅드래곤 810 프로세서와 3GB RAM, 23MP 후면 카메라를 탑재하고 있습니다.
While calling phone screen turns off?
While using any calling feature (phone, facebook, etc) my phone screen goes black and won't turn back on, if the other person doesn't hang up first than I have to manually restart my device to end a call. How do I fix this? Seems to only have started after I installed Nougat 7.1.1.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
can i turn off that sensor that make the screen black when covered ?
댓글 달기
답변 6개
가장 유용한 답변
Do you have a screen protector or a case that may be covering up the proximity sensor? If not, the proximity sensor itself may need cleaning or replacement.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
I had this problem and it was annoying, especially when I had to press the dial pad to go to different services from the number I was calling. So I googled it many times and had all these long winded methods. Then I got a post from a bloke that sounded like he was Russian. When making a phone call and your phone goes blank, just press with you finger in the right hand top corner and the screen comes on again. Thankyou Komrade.
댓글 달기
Make phone call. When screen goes blank, press right hand top corner of screen.
Screens comes on again.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thanks for this very helpful information
Omg it works thank you!!!
2023 still using this trick. Tq very much
댓글 달기
I have that problem also
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well Ensure that the proximity sensor is not being blocked by foreign objects, a screen protector, or a protective case.
Following might be helpful for you: https://wethegeek.com/how-to-fix-android...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi, there is 2 type of problem, first clean your sensor, usually top left of mobile phones, Second may your proximity sensor need to be replace.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i just pressed the top righthand corner and the screen came on !!!** weird or what
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Char Duffett 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 21
전체 시간: 12,143
