주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Cyber-shot DSC-W830은 2,010만 화소 카메라로, 정지 영상 촬영과 최대 720p 해상도의 동영상 녹화를 지원합니다.
transfer photos to computer using windows xp
I had to pull out an old computer using windows xp. Is there any way to transfer the photos from my DSC-W830 to it? Nothing I try seems to work and I can not find any programs to download that willl help. Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
You won't need any programs. The operation is simple.
  1. Take out the SD card and put it into the computer. You will need a SD card or Memory stick reader.
  2. Open windows explorer.
  3. Open the SD card or Memory Stick from there. You'll have to find the correct one.
  4. Drag the photos out of that folder then put them where you wish, probably in the pictures folder.
Hope this helps!
이 답변이 도움이 되었나요?
점수 2
댓글 11개:
Welcome back!
Unfortunately this dinosaur does not show explorer ANYWHERE. I am able to insert the card directly into the computer. The little green light comes on but then ... Nothing :( Thanks for trying. I'm fairly computer savvy but this has me stumped.
TaQu, Click on Start, then Run, and enter in a folder name, like “C:”, and click OK – that should open up Windows Explorer.
George, I miss typed ... that was one of the first things I did. A bit differently but same result. I should have said the card doesn't show up ANYWHERE. I'm sure it is not your advice, it's something wrong with the computer itself. Like I previously stated, I am able to insert the card directly into the computer. The little green light comes on but then ... Nothing . Thanks again for your input.
댓글 6개 더보기
댓글 달기
You need a card reader,then insert the microSD card,then copy the photos on your computer.
The normal way to transfer your photos is to pop the SD card , put it in an adapter and put that in your computer to copy the photo across.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
This Coolmuster Android Assistant, which can remove the limitation of accessing Android internal memory and enable users to backup everything not only from SD card, but also from internal phone memory to PC or Mac computer directly.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
TaQu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 15
전체 시간: 930
