주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
UE Mini Boom은 충전식 내장 배터리, 스피커폰 기능, 라인 입력 및 견고한 디자인을 갖춘 매우 컴팩트한 블루투스 스피커입니다.
Battery replacement for UE Mini Boom?
Is it possible change battery on this device? If yes do anyone know how to do it.
Thank you very much
Update (08/28/2017)
Thank you very much for your help.Well i'v seen already this movies and i manage to open it,also i check the port and looks that the power is coming in,also i took out the battery and test it separetly with external charger and it shows that it charging.How ever when i put every thing together it doesn't show any signs of live.Any way if any body know how to deal with it i will very much appreciate
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Getting into the UE Mini Boom is not that difficult, and soldering in a new battery should be easy; but what to replace the battery with? I've got model S-00136.
의
댓글 달기
답변 1개
선택된 해법
Sorry we don't have any IFIXIT guides for the Mini Boom. Here is a good YouTube Vid that shows a person opening one up: How to open logitech mobile boombox for fixing & UE Miniboom reassembly
Once you get it open you should be able to check the USB port to make sure its working using a Volt meter often the port breakdown so the battery won't charge. If the battery its self is bad you'll need to search the web for a replacement using the info from the battery. Good Luck!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
S.Goland 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 23
전체 시간: 4,528
