주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1996년형 모델은 1995년 북미 국제 오토쇼에서 Chrysler S 플랫폼을 사용하여 처음 공개되었습니다.
car will not move in reverse.
So i have a 97 dodge caravan 2wd 3.3ltr i was backing out of my driveway and it hesitated befor moving but moved about an hour later i got in and put it in reverse and it would not move. Pressed on the gas a little and it still wouldn't move all other gears work and fluids were checked and are good. I can feel it shift into reverse but no movement and when the gas is pressed it rev's and sounds like it puttered like it was about to backfire. Any ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Is the an automatic transmission or a stick shift?
의
Automatic transmission
의
댓글 달기
답변 1개
I would double check those fluids remembering they should be checked warm with the engine running after shifting into all gear options. If this does not work you may have an electrical problem preventing all the necessary solenoids from activating. Your best shot may be to drive it to a repair shop and have them diagnose it. If it is only the solenoid the fix shouldn't cost that much.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sky Simpkins 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 1,920
