주요 콘텐츠로 건너뛰기
The Samsung Gear S3 Frontier (SM-R760 & SM-R765) is a high-end smartwatch designed to reduce the need for your cellphone. Released in November 2016, the device has a 1.3" display, a dual core Exynos processor, and a custom Tizen operating system.
37 질문 전체 보기
How to replace the front bezel wheel?
My Samsung Gear S3 Frontier front bezel wheel is full of scratches and I would like to know if i can replace it, and how.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 달기
답변 4개
가장 유용한 답변
If you can find the replacement wheel. All you have to do is take a very small Jewelers common head, and carefully twist it the wheel will pop off but make sure that you do it in a plastic container upside down. There are four micro ball bearings that will pop out. All you have to do after you take the metal wheel off is take the plastic ring it will look as though it was broken but it is not insert into the bottom of the new wheel put all four ball bearings back in and pop it back on that is all there is to it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi Hugo Trigo,
You are lucky, a tutorial is available on iFixit for your problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi Guys
So. I got given a S3 classic as a present but I wanted the frontier version with the black face. Dial etc.
Is there a way to change the face from classic to Frontier look. I dont want to just change the bezel. I want to change all the silver.
Thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Also if you need the part number for the replacement bezel you can sometimes find them. I had to buy mine from Switzerland. Part numbers Manufacturer Part Number(s): GH98-40541A; GH96-10729A
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Hugo Trigo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 7,770
