주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2007년 말에 출시된 Lenovo ThinkPad R61i는 Intel Pentium 또는 Core 2 Duo 프로세서를 탑재한 보급형 15인치 노트북입니다.
lenovo R61i Boot up problem?
I have a lenovo R61i that i have thrown down for a while and when i try turning it on it boots on lenovo and turn off back and when i touch the power button to turn it on no response.... I disassemble the lop top clean it up and heat the board and assemble it back and it was the same problem....but what i recognize happening to it now is when i disconnect the keyboard it boot up into the bios and stay on and as soon as i connect the keyboard it shot off
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Sounds like the keyboard is bad. Fro your description would assume that is is shorting something on the board. Check both connectors for bent or damaged contacts. If that fails you will need a new keyboard. Good luck!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I will try and get a keyboard and see if its the same problem
의
댓글 달기
답변을 추가하세요
keith hawthorne 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 18
전체 시간: 442
