주요 콘텐츠로 건너뛰기
February 2009 / 12.1 Megapixel / 3.0-inch pivoting LCD / 24x NIKKOR ED glass lens
9 질문 전체 보기
Is my sd card slot broken?
Says can't use this memory card. Menu skips right over format card option.
Says there is a card in when there isn't.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@jsd9086 it is possible that the card reader thinks a card is inserted due to a bend or stuck switch. Your reader will have one tab that gets moved away when you insert a new card and thus recognizes that. If that tab is no longer working properly, your camera will be told that a card is inserted. Of course, you also should try a different memory card. Use these guides to work on your camera
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you oldturkey03
댓글 달기
답변을 추가하세요
Johanna 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 160
