Is my sd card slot broken?
Says can't use this memory card. Menu skips right over format card option.
Says there is a card in when there isn't.
좋은 질문입니까?
좋은 질문입니까?
@jsd9086 it is possible that the card reader thinks a card is inserted due to a bend or stuck switch. Your reader will have one tab that gets moved away when you insert a new card and thus recognizes that. If that tab is no longer working properly, your camera will be told that a card is inserted. Of course, you also should try a different memory card. Use these guides to work on your camera
이 답변이 도움이 되었나요?
Thank you oldturkey03
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 160
