주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bose의 소비자용 액티브 노이즈 캔슬링 헤드폰 라인업은 "QuietComfort"라고 불립니다.
Noise Cancelling Shorting Out
When I slide the control to Noise Cancelling, headphone keeps shorting out and goes in and out between total noise cancel and regular sound. Any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 1개
My power switch seems to not work. Van replacements be found?
댓글 달기
답변 3개
가장 유용한 답변
I found out that - as crazy as it may sound - in my case it had something to do with the battery brand I used.
I normally use Duracells, but always found them a bit hard to insert into the slot (it was really hard to close the lid with the battery inserted), but never had any issues until recently I bought a new pack.
Just for the sake of it I used a battery from a different brand - Varta in that case - and not only do these fit better: Noise cancellation works fine again! No more interruptions, problem solved!
Best regards, Ralph
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Hi Erica, have you tried replacing the batteries and or connecting to another device?
Bose QuietComfort 25 배터리 교체
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have a similar problem, but for me the problem is actually the button itself, just touching it triggers static and it keeps dropping the right channel regularly.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I have this problem too. I fixed it placing a small paper between the button (in "off position") and the headphone panel. It pushes the button a few mm inside the headphone and it appears to solve the problem. I think its a contact failure
what do you mean by between the button and the headphone panel?
A few close-up photos of this would really help!
댓글 달기
답변을 추가하세요
Erica Rubenstein 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 42
전체 시간: 4,859
