주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple Extended Keyboard의 후속 제품으로 1990년에 출시되었습니다. 모델 M0312 및 M3501은 전설적인 ALPS tactile switches/촉각 스위치 또는 Mitsumi standard mechanical linear switches/표준 기계식 선형 스위치를 사용하여 제작되었습니다.
Removing the metal frame
Hello there,
The ^/ ° key went dead, so I soldered a new ALPS tactile switch onto the back - and all of a sudden two more keys refused to function: a & </>
While reassembling the AEK I noticed a copper strip, about 52 mm x 2mm with a drilled hole at one end of it, which hadn't been there before and presumably fell from somewhere between the metal plate and the mother board.
Is there a way to separate the metal plate from the AEK's mother board?
Thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
이미지
Is this what you are trying to do?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Probably a late response but yes, the metal plate can be removed. The only thing holding the steel plate to the motherboard are the switches.
Just have to desolder every single switch .
Once desoldered, just lift the plate, or take out each switch one at a time. Use Rosin Flux and a clean soldering iron tip to avoid damaging the pcb, since it is very old at this point and it is very easy to raise these old solder pads (once you do, they’re gone forever).
Course, that’s a huge hassle.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jirudo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 19
전체 시간: 690
