Had this issue with my 2015 Super-Crew 5.0 liter F150.I first observed the temperature indicator appeared to be in its normal temperature range during summer driving in New Mexico. I shutoff my A/C while the engine was still running, and within 45 seconds the obnoxiously loud, high flow fan shutoff. I shut the engine off for 30 minutes (resetting the computers and sensors). I started the vehicle and let run for 30 minutes, in that time not once did the high flow fan turn on. By segregating the A/C from the rest of the cooling system, I was able to see if the high flow fan was turning on due to the A/C or something else in the cooling system.
I have the equipment and experience to evacuate the refrigerant, contaminants, check for leaks and recharge the A/C. Many people do not and I strongly recommend you have an A/C certified professional do this work. This ensure the A/C system is properly, cleaned out, leak checked and recharged. Pressure verification and contaminant removal prevents an over pressure (or fluctuating pressure) situation as the contaminants can see the 3 states of matter due to the low and high temperatures created during the refrigerant compression cycle. Lastly, most contaminants are injected into the system due to the person recharging not properly cleaning the recharge fitting (Schrader Valve) free of contamination before recharging)
There are essentially 3 cooling interlocks in the F-150 system, and they are interpreted by the trucks software in the following priority
- A/C High pressure sensor/switch (this is # 1 due to the system containing a gas/liquid vapor refrigerant that is compressed to create heat exchange. Pressure increases with increasing temperature, as well as contaminants in the system can create explosive pressures in this system
- Left and Right cylinder head (engine) temperature switches
- Coolant water temperature sensor
2014 f-150 Sox 4x4 5.4 liter My fan seems to be running more frequently than normal and it is loud almost like truck is idling high but why now never have heard it since the truck was knew now at 72,000 miles it has started what is the diagnosis?
Dave62 의
There is no resolution to this problem that i have seen here. I have a 2013 f-150 v-6 turbo charged. Temp can be not even to the normal or even just on start up and both fans running so loud and annoying. Seems to come and go. I did a water pump change and seems to have started after that work(not right away). Kept adding coolant to level as the air worked out of the system( MONTH or more!!) I had read in a blog that can be the problem. Still did it. Then it just stopped doing it. Now starting again. Seems to be associated with A/C system but do not know how. Anyone have any ideas??
james 의
My fan just came on when I got it worked on it stays on and it’s loud it’s never done it before what’s wrong
DeeAnn 의
For James above, we are having a very similar problem. 2013 5.0 v8, car went for last warranty service, they hooked it up to the computer and Ford’s latest update alters the temp the high speed fan cuts in to improve low speed AC performance. We live in Dubai so the thing runs constantly!!! Ford say they can’t change it back either.....We are stuck. It’s the wife’s car and she now wants to sell it!!
Simon King 의
DeeAnn above same goes for your problem, it’s the Ford software that has screwed your car.....
Simon King 의
20에 댓글 더 나타내기
