주요 콘텐츠로 건너뛰기
The PSP 3000 was released in the U.S. on the 15th of October 2008.
92 질문 전체 보기
Umds wont play but video will?
None of my games will play but a video on umd will. I've cleaned the games and the laser on the psp. I updated the software and tried other various things. Sometimes the games will be recognized but they will not play. Please help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 4개
The laser lights up and moves, the motor also works. Sometimes games will load, more often not than they do but I have one video umd that will work. The rest of the psp works fine but will not play games.
Chris did you check on the link to see if that makes any difference? This way we know that all of that works and we can try to further troubleshoot your PSP
yes i did everything the link suggested. do you think the motherboard or the disc drive is bad?
I really hate to say those things since it is difficult to determine that by long distance but I would think that you have an error with the drive. May be you can start of cheap and replace that part first Good Luck to you and do let us know what happens. A chance for all of us to learn more.
댓글 달기
답변 2개
선택된 답변
Chris tell us what you tried. Checked the laser and cleaned it? Removed the battery to reset it? did you check inside the psp unit, notice the rail (silver with lines on it) move or slide the laser which is the square metal box attached on the rail. make sure there is nothing blocking the laser from sliding. The more detail you can provider the more help we can give you. Also check this link it will tell you basically how to trouble shoot and how to fix most of the errors http://www.llamma.com/PSP/repair/PSP_UMD... I hope this will help you out, good luck with your PSP.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
clean the lazer with a tissue e.g. and then hopefully it will work!!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Chris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 1,323
