주요 콘텐츠로 건너뛰기
HTC Desire 620 Android smartphone. Announced 2014, December. Features 3G, 5.0″ Super LCD capacitive touchscreen, 8 MP camera
14 질문 전체 보기
How to repair my phone if it is being wet in the rain?
My phone is being wet in the rain after that it worked for sometime and then suddenly turned off.. When I put it in a container of rice it started working but the touch has not been working properly... And the warranty doesn't includes water damage... Don't know how to fix it....
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Bt It has non-removable battery
댓글 달기
답변 1개
선택된 답변
Hi @anilsynd ,
As you know water and electronics and electricity are not a good mix.
The minerals in the water, cause corrosion and the water also provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts immediately and will not stop until it has been thoroughly cleaned away.
Rice is good to eat but does nothing to fix the problems caused by corrosion
Don't Put Your Device in Rice. Here's Why...
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to completely dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available from most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% or less, can also contain scents and is not as effective. If you do check the label to verify the amount and ingredients
Here is a link that in general describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Here is a link to an ifixit repair guide for your phone which may be of some help to you in dis-assembling the phone.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Hi @anilsynd ,
Bit confused by your comment
I thought that you had a HTC Desire 620.
The battery is removable as shown in the video in my answer.
Also they are readily available online, just search for HTC Desire 620 Battery to find suppliers to see what they look like. Here is just one link to a supplier to give you an idea.
댓글 달기
귀하의 답변을 추가하세요
Anil kumar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 4,627
