주요 콘텐츠로 건너뛰기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 질문 전체 보기
How do you repair torn ground foil on the logic board?
Just received the new logic board for my 5.5 and was able to take everything apart following the how-to document. My only issue was that the Foil removal from the old bard and re-install on the new board was not discussed...or I missed it. Of course I was not careful enough and the the thin lead that goes to the case for ground has torn.
How do I fix it?
As a dosumentation suggestion:
Looks like either here:
iPod 5th Generation (Video) Logic Board Replacement
or at Step 19 (Or new Step 20), we need to instruct on how to remove said foil.
I found that after mistakenly pulling the ground tab piece (which casued the foil break) that peeling up on the round (white underlayment) from the base-end of the logic board is the best method as it does not put stress on the foil itself.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
mbivona, I actually used my old foil as a pattern and got some aluminium foil from the local grocery store and cut it to fit and used some glue, not crazy glue but a non running fabric glue, and put it in place. Worked well for me. Good luck
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I don't think you even need to ground that. It can work without ground.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
mbivona 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 1,087
