How do I replace the LCD Cable
How can I replace the LCD Cable on the Toshiba C75D. I don't know how to disengage it from the motherboard. I don't know if it is soldered or not.
좋은 질문입니까?
좋은 질문입니까?
It looks like it's a cable as in Step 10 here: IBM ThinkPad X41 LCD 스크린 교체
or in Step 12 here: ASUS Laptop K75VM LCD 케이블 교체
This one's actually a Toshiba, if it makes you feel better. Step 7, middle picture: Toshiba Satellite A215 분해도
Basically, it's likely not soldered down but do be careful when unplugging it. The pictures above should give some idea of how to do it, but I'd also say to throw in some patience.
You got this!
안내서
난이도:
조정
안내서
난이도:
조정
30 minutes - 1 hour
안내서
난이도:
조정
25 minutes - 1 hour
이 답변이 도움이 되었나요?
Thank you so much for your answer. I can't see how to unplug it....whether it is pulled straight up....slid to the side, etc. Is there a video somewhere that actually shows how to remove it?
@marie540 Here's a video of someone removing an LCD cable from a Dell laptop (skips to the important part): https://www.youtube.com/watch?v=1_99jpJe....
And here's a video of someone replacing an LCD cable in a Toshiba (skips a fair bit, but it's a long and slow-paced video): https://www.youtube.com/watch?v=FzB4S6hq...
At about 15:32, he says that the cable eventually failed, and opens it up, if you're interested in that. You can see that the wires are frayed and broken, and he recommends opening and closing the laptop as little as possible to reduce the strain on the wires in the hinge.
Hope this helps!
지난 24시간: 1
지난 7일: 2
지난 30일: 13
전체 시간: 1,970
