주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Elephone P6000 Pro는 2015년 8월에 출시되었으며, 3GB 메모리와 옥타코어 MT6753 프로세서를 특징으로 합니다.
Is it possible to replace USB port?
My elephone p6000's USB port has been damaged to the point that has felt from the motherboard that it used to belong to. I have seen some sites that sell a USB port for this specific model, but I am wondering if it is possible to replace it for a new one for a regular user and, if so, which procedure should I follow, since AFAIK there's only a teardown guide explaining how to disassemble Elephone p6000, but does not mention anything specifically about USB port, other than it belongs to a secondary board (visit step 3: Elephone P6000 pro 분해도 ).
Thanks in advance
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
It depends on what you mean by regular user.
The process is quite simple: you just unsolder the old port and then solder a new one. There are plenty of instructions. Just make sure that you follow the instructions.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks for your answer, George! Could you please tell me where are those instructions you are refering to? Although I am quite new to iFixit (just registered), AFAIK there's only a teardown guide explaining how to disassemble Elephone p6000, but does not mention anything specifically about USB port, other than it belongs to a secondary board (Elephone P6000 pro 분해도).
Since the USB has fallen apart from it, I was wondering if I can just simply plug a new one or I have to replace the secondary board.
의 공유
댓글 달기
Its possible but you'll have to find someone who can do it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Carlos 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 30
전체 시간: 1,161
