주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Moto Z2 Play는 2017년 6월에 출시되었습니다. 5.5인치 스크린과 분리 불가능한 3,000mAh 리튬 이온 배터리를 탑재하고 있습니다. 후면 카메라는 12MP이며 전면 카메라는 5MP입니다. 모델 번호는 XT1710입니다.
Screen turning Black when using
Whenever I open an app randomly the screen turns black but the I can still hear the music I am listening to
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 4개
선택된 해법
Try this first
To reboot the Motorola Moto Z2 Play, press and hold the power button on the side of the Motorola Moto Z2 Play until the screen turns off.
Update: Alright, I'll list parts and guide. But honestly it sounds like software, and parts aren't cheap. You should try saving your data and doing a restore
https://m.youtube.com/watch?v=L
https://www.googleadservices.com/pagead/...
https://m.youtube.com/watch?v=CjvbnfAIER...
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
I have tried this but it didn't work
의 공유
Buy an iPhone.
의 공유
iPhone is garbage 😂😂😂 if you dk this I'm scared for you
의 공유
댓글 달기
First thing you must understand if is an hardware or software problem.
In my case it was an hardware problem.
During display substitution proximity sensor was not clean or some glue went above it, or the display was not enough attached to the body (too much pressure breaks the display, too low let it lifted….not easy to mount it properly)
I cleaned all the area in the upper part of the phone, i removed the old glue.
With the display still mobile i tried an app called “Proximity Sensor Reset/Repair” by Mobile Direction.
I did the test (green light means sensor not activated - red light means sensor activated), i did a new calibration, reset phone and it worked.
No more blank screen during calls.
If i put the phone near or far it blanks or lights up…..problem solved (Moto Z2 Play)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hay i have a solution for you
https://biomynt.site/moto-z2-play-screen...
Just go and solve your issue
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I was also facing the problem i solved it by pressing power up + volume down button this is where i found the solution https://okadtech.com/moto-z2-black-scree...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rehan Khan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 25
전체 시간: 8,753
