Rfmodule replacement for xbox slim
where do i get a replacement rf module?
좋은 질문입니까?
here is one http://www.dhgate.com/microsoft-xbox-360... 2.Use in any Xbox 360 console system. eBay has a few on as well http://compare.ebay.com/like/22073459560... looks like the rf module is the same in all 360 GoodLuck
이 답변이 도움이 되었나요?
will it work on slim?
The information that i have is that the modules work in ALL 360, so should not be an issue, but if you are not certain, ask the vendors.
The way it looked to me when I took my 360s apart is that the 360s RF board connector is thinner and longer than the original. I believe this is because the eject button is wired to the RF board (a need for more pins) unlike the original that had a physical button. Also the form is different for the 360s RF board due to the rotation of the USB ports. All that being said this is what you need http://www.ebay.com/itm/XBOX-360-SLIM-Ri...
이 답변이 도움이 되었나요?
You should definitely check on ebay. I purchased a used RF board for my slim xbox and it works perfectly. $5.99
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 8
지난 30일: 14
전체 시간: 1,903
