주요 콘텐츠로 건너뛰기
GMC가 제조한 자동차, 트럭 및 SUV 수리 안내서 및 지원.
290 질문 전체 보기
Possible head gasket symptoms.
In my 1994 GMC Sonoma SLS vin: Z truck, I am slowly loosing coolant. I don't see any leaks though. Is it possible to have a blown head gasket, yet not loose any compression, and not get any coolant in your oil, and not blow any smoke/have a funny smell. Because I have no idea where it could be happening.
PS: I just replaced the thermostat, both hoses, and flushed the whole system.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
To find out for certain if you have a head gasket problem do a leakdown test this video shows an excelent video for this
https://www.youtube.com/watch?v=WgrfT0LF...
Some other things to look for that may cause the the lose of fluids , check the heater core inside the car . look for a wet floor on the passenger side , look for steel coolant lines that may be full of small pinholes from rust . they will release coolant as steam and you wont see any sign of the lose. you can also check for heater hose pinhole that could be dripping directly onto the exhaust and therefore no sign of lose ans it is turned to steam . Check the system cold with pressure . Look at the seams on the rad for moisture . Then run the system up to op temp shut the truck down and then pump up the pressure . This is done with a pressure test pump . Check your PCV valve is working properly . Check the intake manifold for leaks this usually happens in the intake valley under the throttle body . Just some ideas Hope they help
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Holy $@$* man thanks! That is an awsome test for especially my engine to see how good the rings and valves still are. 130k miles can do a lot to an engine!
댓글 달기
가장 유용한 답변
@parzival possible but unlikely. You would see at least one of the symptoms you described. Check your cooling system and preform a pressure check on it. See if there is a leak somewhere. Let us know what year,make and model your truck is.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
1994 GMC Sonoma SLS vin: Z because for some reason they had to rebuild the cooling system after the W models came out. XD
Hi ,
I agree with @oldturkey03 get a pressure test done. You may have a faulty radiator pressure cap or a leak in the radiator core or a heater hose which only shows under pressure.
I know that you said that you don't see any leaks but have you checked for coolant "stains" on radiator, the engine block, heater hoses etc
Also have you checked inside the cabin under the dash? You may have a leak in the heater radiator. Try leaving the heater temperature control set to OFF (or cold) if it not there already, as this will prevent coolant flowing into and through the heater and see if you still lose coolant.
Thanks jey, and I agree. I will do a pressure test with smoke as well. I know for a fact its not the heater coil because just recently I used the heater and there is no fluid on the floor. And if it makes any difference, this leak seems to only happen during normal operation at temp. If that adds any obvious area to check.
I figured it out! Turns out, after I flushed the system, there must have been some places that didn't have coolant in it, so when it ran, it drained the tank. After refilling the tank, it has stayed at a constant level. But thanks guys! I will definitely remember and even do a leak down to test out how good that old engine still is.
댓글 달기
귀하의 답변을 추가하세요
Kevin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 229
