주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 드론은 Wi-Fi를 지원하며 내장형 HD 카메라가 탑재되어 있습니다. 사진 촬영 및 영상 녹화용으로 사용됩니다. 모델 번호: PF722000
My motor stage broken?
it is saying that my motor stage is broken.....can you help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Same problem, though i suspect its the brushes in the motor( a piece that uses electricity to spin the motor and magnets). And my wire on the leg of the drone broke.
의
I have same problem but when I turn it on the perpellar acts like it wants to spin a sec then red-light comes on
의
댓글 달기
답변 4개
가장 유용한 답변
Not connected to one or all motors. Broken cable, connection not seated correctly, (Push Fit) and connection under arms damaged.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
I have this issue.
이미지
이미지
Do I really have to go through the process of taking everything apart in order to fix this?
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Is this un fix able? also the other thing is it wont turn off with the press of the button, I have to unplug battery to turn it off.
의
댓글 달기
As @https://www.ifixit.com/User/3081968/Mich... pointed out this is one or more motor connection issues.
As per https://www.ifixit.com/User/3695100/swiv... from flight app view, we can find which motor is not connected as it’s red.
For me even though how hard I pushed the connector it did not work properly. The connector was loose. (even though I connected a different motor it did not detect by the motherboard.) I used my multimeter ohms scale which has around 1 Ohm per each of 3 pins. I removed the motor connector and sold it directly to the motherboard :). Did the trick for me and saved some money and time as well.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
The motor turn just a little when I first turn on though but then goes to motor stage error
의
댓글 달기
I had the same problem motor stage broken. I unistalled the free flight pro app. Then I reinstalled it and it fixed the motor stage broken. Hope you get the same results
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ciara Refosco 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 18
전체 시간: 5,187
