Location of FM limiter on MB
TLDR: iPhone Bluetooth -> Jabra Cruiser2 -> FM radio = weak/staticky signal... please help!
Can anyone point out what it is I need to disconnect or improve upon on the Jabra Cruiser2 in order to get a stronger FM transmission? It is incredibly weak. Even located mere inches from my antenna the result is weak and static-ridden.
I've tried many stations, the only thing that consistently helps is acting as a signal amplifier by gripping around the unit with my hand. I've been meaning to use a soldering iron anyway ;)
Thanks in advance!
좋은 질문입니까?
Product info: Jabra Cruiser2
Support page: Jabra Cruiser2 - Support
DanJ 의
Before you open the unit how about contacting Jabra to see what they say.
This could be a power issue or the transmitter logic problem. You'll need the schematics to work it out. Do you know how to read them and measure the values?
DanJ 의
Well thank you for the speedy response! That’s unexpected! I wouldn’t know what’s to do with any schematic but Ignite I ever get around Ron contacting Jabra I will let you know. Thanks again :)
k0NStNt CSGO 의
