주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Double Power라고도 불리는 Dopo에서 제조한 Android 태블릿에 대한 수리 안내서 및 지원 정보입니다.
Need to Reset my Password
I cannot remember my original password (password hint did not help) and do not know how to reset it. The tablet states "This feature requires removable media, such as a USB. Please connect a USB Flash Drive, and then try again." This tablet doesn't even have a port for a USB drive. How do I go about resetting my password now?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Seems you have Windows tablet read below and follow the instructions.
You need to choose the second option to reset from your Windows 8 tablet's logon screen. See how to reset Windows 8 password before performing following steps:
Step 1: Start and go to the login screen, look for the power icon on the lower right hand corner of your tablet's screen. Tap on it.
Step 2: Press and hold the Shift key.
Step 3: As the Shift key is clicked or pressed, simultaneously tap on Restart, the tablet will then restart. Now, you will see a screen where you will be asked to choose an option. Tap on Troubleshoot.
Step 4: Finally, choose Reset option, this will begin the factory reset. When using this method, it is best to have a keyboard connected with your Windows 8 tablet for the easy following of the steps. In case you do not have a keyboard you can connect to, start the On-Screen keyboard, which can be found on the options at the lower left hand corner of your tablet. You can find an icon there that represents the Ease of Access. Tap on it then choose the on-screen keyboard. Thanks hopefully your problem will resolve.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you for the support provided above however, it just kept resetting my tablet. Apparently I had to turn it off and then hold down the volume up and the power button at the same time for about 5-10 seconds which then took me to the troubleshoot screen you spoke about above. From there, I was able to follow your reset instructions. Thanks again!
댓글 달기
답변을 추가하세요
Rachel Rabe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 14
전체 시간: 1,608
