주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion g6-1b79dx는 2011년에 출시된 퓨터 색상의 15.6형 노트북입니다. 내장 웹캠과 Intel Core i3 프로세서를 탑재하고 있습니다.
Unable to delete 0 byte file.
I was playing with batch files and accidentaly created a 0 byte, no extention file.
이미지
I googled the problem and I found out that closing explorer.exe and deleting the file via command would help. Tried that. It didn't help. Any software that could do it? Any other suggestions?
Thanks for your help in advance :)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 7개
Honestly, if its doing no harm to the laptop, you should probably just leave it.
의
It's taking up space on my desktop. I need that space :(
의
I would suggest using an administrative login to examine the file permissions. You need to open up the permissions and try the delete again afterwards. Windows file system permissions can make you want to resort to violence at times. Use of cygwin can help sometimes when all else fails.
의
If its just taking up space on the desktop, you can set the file to be hidden so you cannot see it unless you have view hidden files enabled. also what is this File Unlocker thing mentioned in the file description?
의
@professorc I doubt changing the permissions would do anything. Cygwin on the other hand might. I'll try that. Thanx for your help.
의
댓글 2개 더보기
댓글 달기
답변 2개
선택된 해법
As I stated earlier.... Windows file system permissions can make you want to resort to violence at times. Use of cygwin can help sometimes when all else fails.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
Create a new profile in Windows with admin privileges.
Log out of the current profile.
Log into the new one.
Use explorer to go to your other profiles desktop location.
Manually delete that file.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks for your answer but explorer.exe simply does not see the file as... a file. Creating a new account would probably do thesame as killing explorer.exe and deleting the file via cmd which did not help as I said in the question. Thanks anyway.
의
From the new profile open a new profile, open a command prompt with administrator privileages, and then use command prompt to navigate to where the 9 file is. Then "rmdir /s <file name> or del <file name>.
의
댓글 달기
답변을 추가하세요
SLimy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 21
전체 시간: 917
