주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
iPhone 7 plus Camera not working after screen replacement
Hi,
I've just replaced screen iPhone 7 plus for a customer, after that she checked and both front and back camera are not working(I don't know if she broke before or I did it). I have tried to reseat front camera but no help. I replaced aftermaket front camera and it won't work too(I heard aftermarket camera won't work on ios 11???). I haven't tried original camera yet. PLease let me know what happen?
Thank you very much!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
I have a problem with iPhone 7plus camera it had changed the screen and battery but my camera it doesn’t focus when its on photo it shows shaking quality pictures but if i put on portrait its clear picture
댓글 달기
답변 2개
가장 유용한 답변
Hello,
I would recommend an original camera as they tend to always work. You can find these on eBay and ifixit but if you are searching on eBay put in a genuine Apple iPhone 7 plus camera. The best ones that I use are used but high-quality new parts are available on ifixit. Here is the link: iPhone 7 Plus Dual Rear Camera
iPhone 7 Plus Front Camera and Sensor Cable
If an original part doesn't work then this may be a motherboard problem. Also, have a look at the connectors and the connections you are making to the board=. Sometimes they can be a bit off and make a problem. Hope that helped
Replace a front camera and sensor cable compatible with the iPhone 7 Plus. Includes the front-facing camera, one microphone, and the proximity sensor. Part #821-00519-03. 이미지
제품
$29.99
Replace a dual 12 MP rear-facing camera compatible with the iPhone 7 Plus. Fix focusing or sensor issues. 이미지
제품
$17.99
이 답변이 도움이 되었나요?
점수 1
댓글 달기
try disconnecting the front camera and powering the phone on, if back camera works then its your front flex or connection
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kardon3000kardon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 28
전체 시간: 4,489
