주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
iPhone SE no touch after water damage (no meson, no cumulus)
Hi, @refectio
My name is Tomáš and recently i get iPhone SE water damage for repair. After water damage i remove motherboard from phone and clean with ultrasonic cleaner. Phone is booting but touch does not work. I measure supply voltages for Meson and Cumulus, there are all OK. I check connector for short and fuses also. All is okej. I replaced Meson and Cumuls from working iPhone 5s. Now touch is working only with china $@$* LCD, with original one does not work. I again replaced touch ICs, this time i use new one from my supplier and same problem. Touch work only with china $@$* LCD, with original one not.
My primary question is, can i use iPhone 5s touch ICs to iPhone SE?
And secondary question, where can be problem when touch work only with china $@$* LCD? Connector resistance is OK.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The IC's are the same between the iPhone 5S and the iPhone SE. However, the IC's are Cumulus & Sage, not Cumulus & Meson. You have to insure that the IC's you used from your supplier are the correct ones (Sage). It is possible your original screen is defective. Do you have another "original/OEM/Premium" screen to try?
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Thanks for answer. I also try touch ICs from working iPhone 5s, but same result. I tried more original screens of course. Do you have any idea where can be problem?
I do also cracked screen repair. And one question occurred to me. When i repair cracked screens, i can not use china LCD from iPhone 5s for iPhone SE. But original screen from 5s can be used for SE. Why?
I don't know the exact reason, but aftermarket 5S screens don't work (well) on the iPhone SE. The backlight circuits on the respective logic boards are slightly different but I don't know if this is the real cause. I've never really investigated it...
댓글 달기
귀하의 답변을 추가하세요
Tomas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 211
