주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2000년 1월 10일, 2000년 북미 국제 오토쇼에서 처음 공개된 2001년형 Dodge Caravan과 2001년형 Chrysler Town & Country는 2000년 8월에 출시되었습니다.
ignition key wont turn
turned off ignition and now key wont tun at all.How do I fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 12개
i have done a few things sprayed with pb blaster then graphite powder to still see if this will work..........in the meantime bang it with something the key that is tap with hammer it worked for me today 3 out of 3 times the dealer wants 100 bucks just to do a diagnostic on it?
의 공유
This works for me too! Thanks a lot!!!
의 공유
There's a small pawl at the end of the lock cylinder that hangs up in the steering wheel lock. Pull off the plastic covers on the steering column and spray it with some kind of solvent. Hangs up because the old grease is cold or to stiff. Worked for me.
의 공유
Mine did the same thing this morning. After completely melting down, I asked if we could disconnect the battery. Voila! It started and is running again. He said it looks like a loose connection in the battery cable.
의 공유
I just sprayed wd 40 and tapped the key while in the ignition on an 05 caravan and after the 4th tap of the hammer the key turned perfectly..
의 공유
댓글 7개 더보기
댓글 달기
답변 5개
선택된 해법
In addition to what Andrew said: The key or the lock may have broken or worn to the point of not working. Your dealer can make a factory key if given the VIN number.
이 답변이 도움이 되었나요?
점수 6
댓글 4개:
Omg thank you so much you just prevented me from having a freaking major panic attack!
의 공유
Tap with a hammer works
의 공유
Yella Gal How did you tap it, did you tap it in or sideways?
의 공유
It work for for a couple days now it’s won’t turn at all.
의 공유
댓글 달기
가장 유용한 답변
Leave the key in the ignition and tap the end of it with something ( ice scraper works) I use a small hammer I keep in the console, the key will turn.
A locksmith showed me this, works everytime
이 답변이 도움이 되었나요?
점수 15
댓글 36개:
yes it does work but for how long and thank you for that by the way
의 공유
This is a great idea in really work thanks wade
의 공유
Wade . YOU DA MAN. And let us definately not forget to make a shout out to the Awesome locksmith that showed you that. Most are hoping you'll need to call them again , so they won't dare let you in on their secrets
의 공유
Thanks!!! That was awesome. I had to have my van towed home and all I needed was a little hammer.
의 공유
Thank you so much!! How long will this work?
의 공유
댓글 31개 더보기
댓글 달기
One other possible problem is foreign matter in the keyhole. If none of the other suggestions work, you might want to try blowing it out with compressed air. This is usually only problem for people with small children :-)
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Sometimes rotating the steering wheel slightly back and forth while wiggling the key will make it turn. You could also try a different key if you have spares. It is improbable that any corrosion would form inside the ignition key cylinder, but places like NAPA make specific lock lubricants like this with graphite powder suspended in them to help free the pins in stubborn locks.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Banging the key works because it dislodges the lock pawl on the switch. All of you need to pull off the steering column cover and clean the mechanism.
의 공유
댓글 달기
Spray some WD40 in it . insert key few times . then take small hammer and tap key several times while wiggling . This will usually get it to turn . Then you need to replace lock cylinder before it does it to you again .
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
tracym602 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 28
지난 30일: 80
전체 시간: 61,469
