주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
USB C port replacement
What is involved in replacing a damaged UCB-C port on the LG V20? Actually, I could ask a similar question for my iPhone 6S Lightning port. It's been pointed out that one advantage to "wireless" charging is the reduction of wear on power sockets. With daily use, that would be around 700 plug ins over a two year period, so wonder if this comes up often as an issue, and if so, how to replace a damaged power port.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
heres a video of the disassembly https://www.youtube.com/watch?v=5yC0ROV3.... to do the replacement you will need a hot air station, a soldering iron, flux and some leaded solder
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks. I'll review the teardown you supplied.
의 공유
댓글 달기
It can in fact be removed and replaced, but you definitely need a hot air rework station, in my opinion. I did find a YouTube video by a very talented person who was able to do it without a hot air rework station. The video is very well done, and I only wish I had his talent and steady hands.
https://www.youtube.com/watch?v=WgXMjRAU...
I took an old broken LG V20 logic board and was successfully able to remove the connector without damaging the board using my rework station. However, due to the heat, the connector that was removed did not survive. The board was fine, and no other SMD parts were moved or appeared damaged. I know that you can purchase the connector itself on Ebay. Be aware that it has both surface mount pins and 6 thru hole pins as well.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
William Vaughan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 25
전체 시간: 5,624
