주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 2806 / Late 2014 또는 Mid 2015. 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (iMac17,1) 모두 Retina 5K 화면 장착
573 질문 전체 보기
Can I remove failed NVME M.2 Blade drive and just use an SSD?
The NVME M.2 Blade drive has failed on my late 2015 iMac 27 inch. Can I remove it all together and just install use the SSD upgrade kit I got from OWC to run the OS or does Apple somehow require the 32GB NVME M.2 Blade drive to make things work?
I have it torn down as per the iFixit guide. I just want to know if this will work before putting it all back together! :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 5개
선택된 답변
Todd's question has not been answered. Here is what he is saying.
His iMac 27-in came with two drives, an SSD blade and and HDD. The two are linked as a fusion drive. His SSD has failed. His plan is to remove the SSD entirely and not replace it. He'd like to leave the blade slot empty. Instead, he would like to remove the HDD and replace that with OWC'S upgrade kit. In place of his HDD, he would now have an SSD. After the repair, his computer would run solely on the SSD (installed where his HDD used to be), again, with an empty blade slot.
His question is: Will his Mac run normally in the above scenario?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I think you are assuming something we just don't know here. As Todd never came back.
I should have explained things a bit better on what a Fusion Drive is. The HDD is still present after replacing the blade SSD. So replacing it with a 2.5" SSD would be a waste! While you could take out both drives and then put in a SATA drive (any) and leave the PCIe slot empty you then have your data on the HDD which is likely sizable!
I was aiming him to replace the bad blade drive with the OWC blade drive as being the smarter direction. At which point setting up the blade SSD as the boot drive holding your applications and leaving at least 1/4 unused and keeping the HDD with all his stuff in the system. This is the ideal setup!
Frankly, I prefer the dual drive setup when you have at least 500GB blade SSD and a SATA HDD or another SSD. It offers more performance than a Fusion Drive and a Fusion Drive was really intended to be used with a HDD & SSD combo to improve the HDD's performance leverage the SSD as a cache drive to it. Doing a dual SSD Fusion Drive is really pointless! In testing it was found to be slower than just using the blade SSD as the boot drive.
Going with a SATA SSD would be better than a HDD but you leave your data and even better performance on the table not using the PCIe interface. You don't need a massive blade drive to get the benefit.
The best way to express this is like a car not running on all cylinders (like some special cars tried a few years ago), sure it will work, are you getting the full performance of what the car could offer?
댓글 달기
가장 유용한 답변
Just to add to this, I just had the hard drive in my 27-inch 2017 iMac fail. The setup was a fusion drive with an SSD and a (2 TB) HDD. It was the HDD that failed. I pulled out the HDD and replaced it with an SSD (2 TB). I'm booting from that and ignoring the SSD. My iMac has been restored, and it works better than ever.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
@mariodiana - Just keep in mind the SATA port is not as fast as the PCIe/NVMe port. Which is why the blade SSD is more often sought.
@mariodiana, did you remove the blade drive before going this route? I ask because my 128gb fusion drive died but is still being seen in the Disk utility. It will not go away and can not be unmounted, so the system still looks to it and once it finds it, it locks up the unit. This usually takes anywhere from 18 to 22 minutes, but it happens. I already have a 2tb SSD to replace my old school Sata. Is there another way to disable the blade fusion drive before I pull it?
@MarcW58 I did not remove the blade. It’s a while ago now since I did this, and I’m no longer using the machine, but I know that it’s difficult to even access the blade. Sorry to not be of more help! I was able to set the new SSD up as the boot drive.
OK, wait, this just occurred to me. You’ll have to do a bit of googling, but there is a way of joining and breaking the “fusion” of a fusion drive. It’s all done on the command line, and I believe you have to boot into one of the special modes. So, you would first break the fusion, and then you should be able to access the drive separately and do what you want.
Again, I did this a while ago and it’s a little fuzzy in my memory. But this is what I remember. Good luck!
댓글 달기
OK, let first talk about what Apple put in is a small 32 GB SSD and is part of a Fusion Drive set with your current HDD. So we do need to first break the Fusion Drive set before doing anything. Follow this guide: How to split up a Fusion Drive. Now you can remove the blade SSD and put a replacement unit in.
The next question is if you what to recreate the Fusion Drive set or just use them and independent drives.
If you want to create a Fusion Drive set here's how: How to make your own Fusion Drive
Do keep in mind High Sierra has issues with Fusion Drives and OWC's SSD is a RAID'ed SSD which also has an issue with High Sierra. So I would hold off upgrading to High Sierra for now until OWC announces support.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Dan . thanks for the info. I am specifically wondering if I can simply remove the Apple 32GB SDD (what I am calling the M.2 Drive) and just put in a new SSD and then install the OS on that. My problem is that the 32GB M.2 part of my fusion drive is dead according to Apple and they want to replace. But if I can salvage by simply removing it and adding a SSD it seems like it would be a less expensive way to extend the life. As I said I already have it torn down.
Re-read my answer - Yes you can replace the blade SSD and put in a new one, and yes you can install the OS onto it.
Lets not use the term M.2 as Apples SSD does not use the same physical interface. You must use the correct SSD here.
Dan,
OK to be clear I can replace the blade SSD with a OWC SSD Upgrade Kit. In other words the blade SSD slot will now be empty and I will install the OWC SSD upgrade kit. Thanks for you help.
You want the Slot version of SSD OWC Aura Pro X2
댓글 달기
The original question wasn’t answered still
from my undertanding of the owners post they the owner does not want use the blade nvme drive because they dont want to replace a broken nvme which is part of the ‘fusion drive’. They want to replace a rotational HDD which was used as storage with a SSD and install and run the macOS/storage on that alone. Will it work, YES
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Yes it was, its a bit confusing so lets break it down: The blade SSD in Todd's Fusion drive failed (Apple custom blade SSD) so the question was can he replace it and the answer is yes, using an OWC blade SSD which is pin compatible with the custom blade SSD connector in the system. At which point Todd could redo the Fusion Drive or run the blade SSD independently (which I strongly agree is the better). His HDD (spinning rust drive) was still working so it didn't make sense to replace it.
Replacing the HDD adds complications, as you would need to mount the drive externally to recover the stuff thats on it. And yes you could do that as well.
He jumped around a bit so we never got a clear idea what he wanted. I could read his question and comments to be either replacing the blade SSD or replacing the HDD with a SSD.
"Can I remove failed NVME M.2 Blade drive and just use an SSD?" sometimes we just don't see what's in front of us... this was the original question and its answer was and still is 'yes'
thank god an answer that didn't look and sound like common core math problems
댓글 달기
You can use pcie ssd standalone. If you wipe nvme it will appear as separate drive of small capacity unless you plan to recreate fusion drive utilizing both drives.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I should have said small capacity PCIe NVMe blade ssd can be left wiped clean or blank once formatted if conventional SSD is to be used only. The main real world experience is boot times when macOS is located on NVMe. NVMe drives can usually deliver a sustained read-write speed of 3.5 GB/s in contrast with SATA SSDs that limit at 600 MB/s.
댓글 달기
귀하의 답변을 추가하세요
Todd 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 15
전체 시간: 889
