주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony DVD 플레이어 수리 및 분해 안내서입니다.
DVD door will not open
This model is RDR-VX515, VCR/DVD recorder combo. When I press the eject button I hear a noise as if the ejection process has begun. Then the tray does not open and I get the message "LOAD" as if the tray has opened and I have closed it. The next message is "NO DISC."
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
I would take the cover off, then plug it in and press the eject button to see whats preventing it from opening. Sometimes the mechanism that holds the DVD in place can get stuck, or something could be jammed in that whole mechanism chain ... you'll see what i'm talking about when you observe it with the cover off. You should not need to take anything apart ... just watch it when you try to eject and the cause of it should be obvious. Post back if you can't figure it out or you see something and don't know how to handle it.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
This is a Wonnie DVD player, the DVD door is opened by pressing on the door. There is no eject button.
의
댓글 달기
답변을 추가하세요
Glenn Stoops 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 4,094
