주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
가정용 전기 설비는 전력을 집 안으로 끌어오고 다양한 콘센트, 가전제품, 조명 기구로 배분하는 복잡한 전기 구성 요소 시스템입니다.
What kind of bit could I use
Where can I find a proper bit for this kind of screw?
이미지
These screws on the bottom of the battery case
Update (11/15/2017)
This power cord is produced by a Czech company Emos model HE1313 (E1313).
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
That appears to be a security type of screw. Please tell us the make and model number of what it's on.
댓글 달기
답변 2개
가장 유용한 답변
Here's the bit you'll need: Tri-Groove-Nut-Driver 1/4" socket
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you, but I'm not sure if the screw hole is wide enough for this bit.
http://nevada.pl/power_cord_screw2.jpg
http://nevada.pl/power_cord_screw3.jpg
Seems to be smaller than 1/4"
댓글 달기
This type of screw seems to be common in power strips in (some parts of) Europe. Its head is only about 5mm in diameter at its thickest, and they tend to be seated quite deeply within the power strips, making extraction difficult. It also seems to be a genuine “security” screw because it really is difficult to find a driver for it. The closest match in dimensions seems to be the “#6” tri-groove socket that’s sold in the US, but on the pictures it appears too thick to fit the deep screw holes in these power strips.
I’d managed to drive it with snake-eyes but it wasn’t efficient and it definitely won’t work for fastening it back into place.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Yes, but it would be nice to find a source for this socket. Do you know of the kneedle points of a ring expander would work?
댓글 달기
답변을 추가하세요
Driver 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 14
전체 시간: 1,043
