주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2009년에 출시된 iRobot Roomba 560은 자동 로봇 진공 청소기입니다.
Roomba 560 Charging Problems
My Roomba 560 stopped charging. Instead the Clean button flashes orange every 2 seconds or so, with a clicking sound. After researching, I bought a new battery online and installed it. It then powered on fine but when I put it on the charging station, it flashed red stating "Charging Error 1." It then reverted to the orange flashing Clean button accompanied by the clicks. I checked and the battery is seated properly. It's also the same whether plugged in directly or in the charging station.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Try resetting the roomba’s software using the spot and dock buttons. Did you try plugging the roomba in directly via the charging port? Make sure that the charging contacts, home base contacts, and battery contacts are not dirty. If they are, use a clean, damp, and lint- free cloth to wipe them off. If that doesn't help, replace both the charger and the home base. If ALL of these fail, contact iRobot customer support as it is most likely a motherboard issue.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Roomba Warrior 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 861
