주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
삼성에서 최초로 선보인 8인치 안드로이드 태블릿입니다.
Why does my tablet keep freezing?
Hi my tablet keeps freezing, I have tried a factory reset but that still hasn't helped. Freezing seems to occur randomly . Usually it's when I try to play a game but it's also froze when I'm doing nothing. Once the tablet is froze I have to hold the power button down to get it to restart and it occasionally hangs on the Samsung logo, which requires me to hold power button again and again until it decides to boot . My battery is pretty poor and the tablet spends most of its life on charge. Is it possible this is a battery issue or something else?
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 7개:
its not a battery issue I would recommend to get it checked somewhere
Not sure what else it could be other than the battery, I've done a hard reset so it's not the software,it's not water damaged or anything .anything else I could check?
Did you just factory reset your phone through Settings or flashed the ROM? If not, try it.
Just factory reset. I will try flashing today
So I have flashed stock firmware and still freezing, I have noticed that it only really freezes after the tablet has been charging. Sounds like maybe the tablet is overheating while charging maybe? Any ideas?
댓글 2개 더보기
댓글 달기
답변 1개
Try freeing up space that should speed it up.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I don't need it to speed up, just to stop freezing
Buy a SD card which will give you more hard drive space.
댓글 달기
답변을 추가하세요
John 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 5,671
