주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
FaceTime Camera do not work after changing Flex
Hello everyone, I have a problem With an iPhone 5C.
The Facetime camera does not work on any app (Photo, Facetime, Snapchat...)
I've change it and it still doesn't work with a ne piece (I've tried 5 different flexes)
I tried to reset the settings, reset the devices and it still doesn't work.
Do anyone had this problem ?
Thank you !
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
iPhone 5c Front-Facing Camera and Sensor Cable Replacement
Use this guide to check your sensor cables and for help if they need to be replaced.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Please remember to ensure all connections are snug, and you do a hard reset after each replacement.
if you have tried 5 flexes from a trusted supplier, then i would follow the steps below.
1) Try replacing the other camera: the circuits in iphone cameras are linked, and sometimes, a small discrepency in the other camera can be the cause of a fault in the one you are struggling with.
2) Damaged or missing components: Using a microscope for this helps. scan the board for missing components, or scratches and chips out of ICs, and coils.
3) Reflow the FPC Connector on the board: Make sure there are no damaged pins, and reflow the connector to ensure connection to the board.
4) use a multimeter to check for continuity of the coils (Resisters, inductors, caps, etc) around the connector for your camera flex, and replace any that are not getting a full circuit.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thank you very much, I try it and I send you a feedback !
anything further than these, will be a problem with the Front Camera Control IC. this replacement requires a board diagram, with labels pointing directly to the component. i tried a quick google search, and couldnt find an image for you. there is a possibility that someone else on here has access to the OEM drawings.
댓글 달기
귀하의 답변을 추가하세요
Aurélien Patricio 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 66
