주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4.3인치 와이드스크린 LCD 디스플레이와 333 MHz 프로세서를 탑재했습니다. 모델 번호는 PSP98510입니다. 이 기기를 수리하려면 일반적인 스크루드라이버와 분해 도구가 필요합니다.
It doesn't turn on
Hi, everything started when backlight just stopped working. Like your turn it on one times it works but other time after a few minutes it just stopped working. And then even it doesn't turn on anymore. Like if you're charging orange comes on but fades off after a few minutes and PSP won't turn on anyways. Please help :(
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Let's try this: press and hold the following combinations of keys: Triangle + Square + Start + Select. While holding the buttons, flip the Power button in order to switch the device on. Release all keys as soon as the Sony logo appears on the screen (if it does).
If not, try powering it up while the charger is plugged in, but not the battery.
There is not much I can do about the backlight other than suggesting that you replace the screen.
이 답변이 도움이 되었나요?
점수 3
댓글 5개:
Oh, the problem is that Start button isn't working so I can't try that combination. I tried it turning it on without battery in it, it didn't help.
의 공유
Alright so what else is not working? How do you even pause a game if the Home bar isn't working right?
의 공유
For now I suggest that you take your console apart, reconnect the LCD ribbon cable and the Home bar cable and see if anything changes.
Also, is the front case seated properly? or are there gaps between it and the chasis?
의 공유
The thing is, the button is just broken from inside. I don't know how to explain it in English. I'll try to reconnect LCD ribbon, yes front case is seated properly.
의 공유
You could just add a picture of the damage of the Home bar
의 공유
댓글 달기
답변을 추가하세요
Tomasz Videos 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 21
전체 시간: 1,176
