주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chevrolet Cruze는 General Motors의 Chevrolet 부문에서 제작한 소형차입니다. Cruze는 2008년에 전방 엔진, 전륜 구동 레이아웃으로 처음 출시되었습니다.
Window stuck rolled down
My husband rolled down his drivers side window this morning and it will not roll back up. It's a 2015 so shouldn't be an issue yet, but unfortunately it is. He can hear the motor for the window, but the window is stuck down in the door. Any tips/tricks on how to get it to come back up without having it replaced or taken to a shop?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 6개
I also have this problem on my 2014, and I just put a new regulator and moter. It rolled down but wont roll up again.
의 공유
@raycruze Hi, Raymond. The Chevy Cruze is notorious for having the windows slip off the track. I just saw one with both the passenger and driver’s side windows off the track this last week. You’ll need to take the door panel off and most likely replace the regulator, although sometimes you can put the window back on the track without having to replace it. Look for the broken bits of plastic that hold it in place. Here’s a video of someone performing the repair you need. Good luck!
https://www.youtube.com/watch?v=wJQLo2do...
의 공유
Tried to roll window down didn't realize it was frozen heard a loud pop can hear the motor running but window won't roll down. What can thank be. 2014 Chevy Cruze
의 공유
You need a window regulator, if can hear motor wont need one with motor.
의 공유
We just fixed / replaced the window regulator on our 2015 Chevy Cruz. Now it tells me that my door is opened, and says to roll/ open close my window, my doors won’t lock, radio won’t turn off when you open the door and when I roll the window down it’s extremely slow to roll up. What can I do or should I take it in?
의 공유
댓글 1개 더보기
댓글 달기
답변 1개
선택된 해법
Hi, Shea. The Chevy Cruze is notorious for having the windows slip off the track. I just saw one with both the passenger and driver’s side windows off the track this last week. You’ll need to take the door panel off and most likely replace the regulator, although sometimes you can put the window back on the track without having to replace it. Look for the broken bits of plastic that hold it in place. Here’s a video of someone performing the repair you need. Good luck!
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
I am trying to find a diagram on how the regulator works on a 2015 Chevy cruise. I have seen several videos on how to replace it but I want to see how one works when it is functioning normally
의 공유
what if the window is stuck down on passenger side and when we use the switch on the drivers side and the passenger side it clicks...which means???
의 공유
The answer guy, did not inform how to get a stuck window up! While door panel is off my car, I still can't get window up . And this answer isn't an answer! It's am idiot!
의 공유
댓글 달기
답변을 추가하세요
Shea Alyson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 26
지난 30일: 166
전체 시간: 110,325
