주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Officejet 6500은 컬러 복합기입니다. 2003년에 출시되었습니다. 모델 번호: CB815A#B1H.
What does the code 0x61011beb mean?
Printer code 0x61011beb
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
If all that software stuff doesn’t change your problem, there is a small plastic gear that likes to break in an armature inside the right side of the printer at the end of the silver rod that runs side to side through the whole printer. Once this happens, the print head can’t be properly positioned so you get the general error you posted. You can pop off the right side panel on the printer and the armature slides right off so you can access the gear. If it’s just cracked, you may be able to super glue it together and then reinstall everything and be good to go. If it’s destroyed, you’ll have to get a new gear somewhere. You might also try taking the pressing the broken pieces together into some clay or wax to make a mold which you can fill with super glue to make a new unbroken gear. Here’s a video showing a replacement being done on a 6500A Plus: https://www.youtube.com/watch?v=o8p9s7kI...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Could be a driver issue or the printer and cartridges aren't talking to each other.
Hit the link below for a fix I found:
http://www.personalcomputerfixes.com/how...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Evelyn King 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 32
전체 시간: 3,581
